Todo está según manual para cargar el programa.
El puerto de conexión desde MAC es wchusbserial1410. Si no está on el interruptor, la placa no detecta el puerto serie.
Todo el mensaje que genera:
System wide configuration file is "/Applications/mBlock_v3.3.1.app/Contents/Resources/Arduino/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/**/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.wchusbserial1410
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x56
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x69
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6e
avrdude done. Thank you.
09:03:06.395 < 00
09:03:07.890 < 00
09:03:10.052 < 56 65 72 73 69 6f 6e 3a 20 30 36 2e 30 31 2e 30 30 35 0d 0a
Al acabar la carga hacer unos sonidos pero no carga el programa
User configuration file is "/Users/******/.avrduderc"
09:03:06.395 < 00
09:03:07.890 < 00
