Tengo una placa ME Orion y no me deja actualizar nada desde el ordenador, ya que ni actualiza el firmware ni descarga la progamacion en la placa para usarla de forma independiente.
Esto me dice:
is not responding
avrdude.exe: stk500_recv(): programmer is not responding
avrdude.exe: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2b
avrdude.exe: Send: 0 [30] [20]
avrdude.exe: ser_recv(): programmer is not responding
avrdude.exe: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2b
avrdude.exe: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2b
avrdude.exe: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2b
avrdude.exe: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2b
avrdude.exe: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2b
avrdude.exe: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2b
avrdude.exe done. Thank you.
Tengo una placa ME Orion y no me deja actualizar nada desde el ordenador, ya que ni actualiza el firmware ni descarga la progamacion en la placa para usarla de forma independiente. Esto me dice: is not responding avrdude.exe: stk500_recv(): programmer is not responding avrdude.exe: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2b avrdude.exe: Send: 0 [30] [20] avrdude.exe: ser_recv(): programmer is not responding avrdude.exe: stk500_recv(): programmer is not responding avrdude.exe: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2b avrdude.exe: Send: 0 [30] [20] avrdude.exe: ser_recv(): programmer is not responding avrdude.exe: stk500_recv(): programmer is not responding avrdude.exe: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2b avrdude.exe: Send: 0 [30] [20] avrdude.exe: ser_recv(): programmer is not responding avrdude.exe: stk500_recv(): programmer is not responding avrdude.exe: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2b avrdude.exe: Send: 0 [30] [20] avrdude.exe: ser_recv(): programmer is not responding avrdude.exe: stk500_recv(): programmer is not responding avrdude.exe: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2b avrdude.exe: Send: 0 [30] [20] avrdude.exe: ser_recv(): programmer is not responding avrdude.exe: stk500_recv(): programmer is not responding avrdude.exe: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2b avrdude.exe: Send: 0 [30] [20] avrdude.exe: ser_recv(): programmer is not responding avrdude.exe: stk500_recv(): programmer is not responding avrdude.exe: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2b avrdude.exe done. Thank you.
Si ya has instalado el "driver de arduino" desde mBlock y te sigue dando esos problemas es posible que tengas el Bootloader corrupto.
Si dispones de otra placa de Arduino puedes restaurar el Bootloader siguiendo este tutorial:
http://www.makeblock.es/foro/topic/223/tutorial-quemar-bootloader-mcore-orion
Si ya has instalado el "driver de arduino" desde mBlock y te sigue dando esos problemas es posible que tengas el Bootloader corrupto. Si dispones de otra placa de Arduino puedes restaurar el Bootloader siguiendo este tutorial: http://www.makeblock.es/foro/topic/223/tutorial-quemar-bootloader-mcore-orion
182
